mediatek mt8127a supported or not ............ its just lock at sturtup pendo chinies tab me dissamble it make its cpu shot try to unlock it with software https://forum.gsmhosting.com/vbb/****************************/?zn9rbpauk75q8ne team as soon reply me its possible....... unlock security code other all ok .. Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0xD8 Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v218.218 on BBID : 0x27 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:09 Reconnect Power/Cable! if me click at reset privacy lock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0xD8 Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v218.218 on BBID : 0x27 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Phone not support that feature!!! Operation useless Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
if me click at formate Operation : Format FileSystem [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0xD8 Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v218.218 on BBID : 0x27 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
Hello. 8127 CPU is little bit differs, not have it yet. When got - will be added. |
