03-30-2018, 17:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | Meizu M3 Note |
03-30-2018, 18:14 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-09-28.22:36 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D420701BB6A84A38F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xE149063A2891B41C8536BA1E6D590AB8 INT RAM : 0x00040000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Meizu ProdName : meizu_M5 Note ProdModel : M5 Note Device : M5Note AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : alps-mp-m0.mp7-V2.3.1_wt6755.66.n5.m_P92 Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
03-30-2018, 18:22 | #3 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SUCCESSFULLY REMOVE USER LOCK & FRP(MEIZU M3S LOCKED with SLA MT6755 Helio [P10])USB Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone ... Phone found! [ 28 ] Sync ... Inital Boot Ok! BB_CPU_PID: 6755 BB_CPU_NME: [MediaTek] Helio [P10] | MT6755_S00 BB_CPU_EXT: 0xCB00, 0x8A00, 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal: 0x07000000 BromVer: 0x00FF BLVersion: 0x0001 PreLoader: Active [Boot with PL] BootLdrSS: LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-07-13.22: 34 Sending and initialize DA ... DAgent configured successfully Connection agent: PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC]: FLASH_VEN: 0x15, OEM: 0100 [eMMC]: FLASH_INF: [SAMSUNG], BM328 [eMMC]: FLASH_CID: 150100513832334D420019E797B2733B [eMMC]: FLASH_BRT: 0x00400000, 0x00400000, 0x00400000 [eMMC]: FLASH_LEN: 0x00000003A3E00000 [eMMC]: FLASH_UCP: 14910 MiB [eMMC 16 GiB] DEV RID: 0x761800CE85B6B94770B9D32B9CA99088 INT RAM: 0x00040000 EXT RAM: 0x80000000 [2 GiB] [NAND]: FLASH: NOT INSTALLED [UFSM]: FLASH: NOT INSTALLED [HSUSB]: MODE: HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:39 Reconnect Power / Cable! ================================================== ================================================== ================ Operation : Format FileSystem [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone ... Phone found! [ 28 ] Sync ... Inital Boot Ok! BB_CPU_PID: 6755 BB_CPU_NME: [MediaTek] Helio [P10] | MT6755_S00 BB_CPU_EXT: 0xCB00, 0x8A00, 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal: 0x07000000 BromVer: 0x00FF BLVersion: 0x0001 PreLoader: Active [Boot with PL] BootLdrSS: LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-07-13.22: 34 Sending and initialize DA ... DAgent configured successfully Connection agent: PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC]: FLASH_VEN: 0x15, OEM: 0100 [eMMC]: FLASH_INF: [SAMSUNG], BM328 [eMMC]: FLASH_CID: 150100513832334D420019E797B2733B [eMMC]: FLASH_BRT: 0x00400000, 0x00400000, 0x00400000 [eMMC]: FLASH_LEN: 0x00000003A3E00000 [eMMC]: FLASH_UCP: 14910 MiB [eMMC 16 GiB] DEV RID: 0x761800CE85B6B94770B9D32B9CA99088 INT RAM: 0x00040000 EXT RAM: 0x80000000 [2 GiB] [NAND]: FLASH: NOT INSTALLED [UFSM]: FLASH: NOT INSTALLED [HSUSB]: MODE: HIGH-SPEED Boot Ok! Clear FRP (Google Reset Protection) Clear Ok! Clear PVL (PrivacyLock) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power / Cable! |
03-30-2018, 19:50 | #4 (permalink) | |
Member: 1898289 Status: Offline Thanks Meter: 39 | Quote:
Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! | |
03-30-2018, 20:22 | #5 (permalink) | |
Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! | |
03-31-2018, 04:03 | #6 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2739340 Status: Offline Thanks Meter: 74 | Logs say needs to change DA file Download DA file Helio p10 mt6755 from support area replace in boot folder and to connect phone need to use combination key like volume up or volume down or both and you will success |
