Old 06-16-2016, 17:35   #1 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 326
Meizu Note 2 how to service that model?
Operation : Format FileSystem [ v1.49 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Also Huawe Y330 can not be flashed via our paid tool, while can be easily services using original SP flashtool
and many other options missing
many phones I can't flash with the flash files that I have from the net, while I flash those phones successfully with SP flashtool.
What is the purpose of buying this tool?
Old 06-16-2016, 17:44   #2 (permalink)
Member: 21296
Thanks Meter: 326
It seems to me that just servers for telling us which phone has secure boot and which one has not secure boot
Old 06-16-2016, 17:54   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,696
For you - none. I told that before
If you can't use it - forget about it.
Old 06-16-2016, 18:17   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,206
Hello brother,Huawei Y330 was supported till Cm2 ver 1.40.also you can sp unlock it & other supported features by Cm2
I think there is no Box on this forum fully supports Meizu phones.
Hope team Will add it soon, stay tuned,you will get the purpose of buying this Tool.
Wbr
Old 06-16-2016, 18:46   #5 (permalink)
Member: 21296
Thanks Meter: 326
Tell me how do you flash Huawei Y330 then?
It is impossible or even if it is possible it takes 20 minutes till you find the way, but using free SP tool just select files inside Rework-Secro folder first and then all the files from the main firmware folder, and in 7 minutes we have a working phone..
Cm2MTK says:
[SCATCHECK] : Missing File : \USB_Upgrade\Rework-Secro\MBR
[SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter!
for Y330 flashing
Old 06-16-2016, 19:40   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,206
Cm2MTK says:
for Y330 flashing
What is your problem brother?
Seems you are PLANTED HERE BY COPY TOOLS
DID YOU BOUGHT CM2 FOR FLASHING Y330 ONLY ??
if its true,better through it AWAY to DUSTBIN.
Leave Proffessional CM2,Better use SPF TOOL Forever.
Good luck
Thanks for Understanding.
Page generated in 0.23770 seconds with 7 queries
