05-22-2018, 16:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | meizu note 2 passcode I have meizu note 2 with passcode and I tried to reset with cm2mtk and cm2mt2 holding both volums and it gives me error. I saw that somebody on the forum manage to reset it, I used the same DA MTK_AllInOne_DA_v3.3001.00.00, but still error. Any idea? Thanks! |
05-22-2018, 16:48 | #2 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 139 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
05-22-2018, 16:49 | #3 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | and a user from forum did it Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132380F8B0042EB32CAD0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42008B0FD0CA82EB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x69E25B9ADDA10807BF612D271EBF30BA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Meizu ProdName : m2 note ProdModel : m2 note Device : m2note AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1.8.2_MEIZU6753.65C.L1 SECURITY : IMEI_SW [1] : 868597023673847 IMEI_SW [2] : 868597023673854 BTMAC Addr : 683E348263E3 WiFi MAC : 683E348263E2 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_CMCC_MP_V9_P30_1 _ltg_n EXTRA : LCD : Not info available LCD Res : 1920x1080 TOUCH [0] : MZ_GT9XX TOUCH [1] : MZ_FT5346 CAM [0] : s5k3l2xx_mipi_raw CAM [1] : s5k3l2xxge_mipi_raw CAM [2] : s5k3l2xxliteon_mipi_raw CAM [3] : s5k3l2xxliteonge_mipi_raw CAM [4] : s5k3l2xxavc_mipi_raw CAM [5] : ov5670_mipi_raw CAM [6] : ov5670film_mipi_raw CAM [7] : ov5670tech_mipi_raw CAM [8] : ov5670avc_mipi_raw MODEM : lttg lwg LOCALE : zh_CN en_US zh_TW Done! Elapsed: 00:00:09 |
05-22-2018, 16:50 | #4 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132380F8B0042EB32CAD0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42008B0FD0CA82EB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x69E25B9ADDA10807BF612D271EBF30BA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:07 |
05-22-2018, 17:30 | #5 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | btw, those are logs from the guy that managed to reset the phone, not mine. so any idea, somebody? thanks! Trimis de pe al meu WAS-LX1 folosind Tapatalk |
05-22-2018, 18:45 | #6 (permalink) | ||
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
Either your model not same as other user boot done Or ur phone have different hw varient/ can be different model too (who locked with SLA) which need specific auth+DA+EMI to boot... Try in MT2 version with select meizu or check model no. Fastboot getvar will help | ||
