03-31-2016, 21:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | problem repairing imie vodafone 696 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420028B3DC96820B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420028B3DC96820B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 80069128EA8C167DAD8026660F9283DC INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Burned OTP detected! Operation USELESS! IMEI_OTP [1] : 353053071214433 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Repair Security [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6580, E01 HW : MT6580, E01 SW : MT6580, E01 MM : MT6580, E01 VR : MOLY.WR8.W1449.MD.WG.MP.V6 SN : 2000.00.00 Security Info : IMEI [1] : 1.0 IMEI [2] : 03 IMEI [3] : 353053071214433 IMEI [4] : 353053071214433 Read Ok! Update IMEI[1] to : 354675790964457 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:17 Reconnect Power/Cable! |
03-31-2016, 22:13 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Burned OTP detected! Operation USELESS! That mean you can "repair" imei only with eMMC ic change, then refilling new one. |
