Old 04-01-2017, 17:03   #1 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 237
MI MAX hangs while connecting
Card found : xxxxxxxx , v0135
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11
Operation : Reset Settings [ v1.11 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 652 [MSM8952]
ID_BLOCK_S : 030D482F
ID_BLOCK_I : 009900E1
ID_BLOCK_L : 2F68FBD7656C54078EC26ED94D39C1F6
ID_BLOCK_L : D7215BFA3D1C36E4936AAF9AE5519DC0
Use CM2 Internal Loader
it hangs at this stage and when remove cable gives this
FH_LOAD_CODE : 14
Error : Loader send failed!
Check cable, connection and drivers!
Reconnect Power/Cable!
Old 04-01-2017, 21:39   #2 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 237
Loading firmware ...
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000001D1F000000 [ eMMC 128 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HDG8a4
Boot Ok!
MIAccount reset passed!
Normal reset :
> Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings"
> PowerOn device and use. IF Device stuck on black screen with cable - use another FMT
> Not all devices supported yet! (tested on Hydrogen,Land,Redmi2)
Done!
Elapsed: 00:00:29
problem solved after sletcting firmware file sotware uses loaders from soft instead of internal loaders
regards
Page generated in 0.12382 seconds with 8 queries
