Old 07-28-2017, 22:00   #1 (permalink)
Member: 85718
Thanks Meter: 449
Mi MIUI8
Hello, I have this phone with Account, is possible remove?
Pressing vol+ and vol- Connect to Qualcomm software but when do that phone start charging and no USB port detected, with phone power off, if I press vol- and insert usb cable phone goes to Fastboot mode. Any way to solve this ?
Old 07-28-2017, 22:06   #2 (permalink)
Member: 85718
Thanks Meter: 449
The phone model is Redmi 3S.
Old 07-28-2017, 22:43   #3 (permalink)
Member: 1677653
Thanks Meter: 2,769
All latest Qualcomm phone work with EDL cable or test point
Old 07-29-2017, 15:20   #4 (permalink)
Member: 85718
Thanks Meter: 449
Thank you for answer, where I could find test Point schematic? Or the EDL cable schematic?
Best regards .
Old 07-29-2017, 19:32   #5 (permalink)
Member: 2043843
Thanks Meter: 39
Test point for Redmi 3s /3s prime
Best regards .
Unbrick Redmi 3s Testpoint Method (Hardbrick Only) - Redmi 3S/Prime/3X - Xiaomi MIUI Official Forum
The Following User Says Thank You to vishal110094 For This Useful Post:
Old 07-30-2017, 12:51   #6 (permalink)
Member: 85718
Thanks Meter: 449
Hello, thank you for your answer, my phone is working (not bricked) but have the account , to remove is necessary the test Point , or only need EDL cable?
Old 07-30-2017, 13:43   #7 (permalink)
Member: 1677653
Thanks Meter: 2,769
You can order for the EDL CABLE here https://gsmserver.com/item/cables-an...le-for-xiaomi/ or buy at any nearby GSM market
Old 07-30-2017, 16:15   #8 (permalink)
Member: 2043843
Thanks Meter: 39
Edl cable not worked in MiUi 8.
After MiUi 8 update Edl cable not worked in many model so user need to short test point to do unlock/force flash phone or do other opration.
Old 08-31-2017, 03:28   #9 (permalink)
Member: 85718
Thanks Meter: 449
Now I have received the EDL cable and I could read firmware with infinity , but don’t know the correct way to remove MI account . Someone could help me?
Old 08-31-2017, 04:42   #10 (permalink)
Member: 1228709
Thanks Meter: 268
In format options, select Remove MI account, press Format FS/Reset Settings and wait for results.
Old 09-01-2017, 00:23   #11 (permalink)
Member: 85718
Thanks Meter: 449
Well, I don’t know what version are you using, in my version 1.15 I don’t have the option Remove MI account , I have
-FULL WIPE (USER/CACHE/FRP)
-WIPE DATA/CACHE
-RESET FRP
-REPAIR DATA/CACHE/MSC
-FORCED FIX (USER/CACHE/MSC)
-XIAOMI:RESET ACCOUNT
-XIAOMI:REMOVE FIND MY DEVICE APP
I pressed the XIAOMI:RESET ACCOUNT , when process is finished phone restart but crash at start MI icon , if i flash with initial backup created , the phone continue with account activated.
This is the version i have in phone:
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : Xiaomi
Device Manufact.: Xiaomi
Device Model : land
Device CPU : MSM8937
Device IntName : land
Device Version : 6.0.1
CU_SWVer : Xiaomi
Device Compile : 27-04-2017 03:05:26
Device ExtInfo : Redmi 3S
Load Ok!
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Old 09-01-2017, 11:03   #12 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
-WIPE DATA/CACHE
-RESET FRP
Device Model : land
CU_SWVer : Xiaomi
Load Ok!
Hello,
After Reset Account format again with Forced Fix or Repair Data option and wait for 15 min for phone to boot up fully. If phone again ask for account on internet connection then use last option- -XIAOMI:REMOVE FIND MY DEVICE APP
Br.
Infinity Box Team.
Old 09-01-2017, 23:06   #13 (permalink)
Member: 85718
Thanks Meter: 449
Well , no luck, if choice RESET ACCOUNT at the end operation phone restar and crash at mi , check picture.
https://postimg.org/image/xc8yzm2md/
Old 09-01-2017, 23:13   #14 (permalink)
Member: 85718
Thanks Meter: 449
If I choice RESET ACCOUNT + FORCED FIX (USER/CACHE/MSC) when Phone restar I have this
Old 09-01-2017, 23:21   #15 (permalink)
Member: 2592600
Thanks Meter: 19
just dongrade to mui 7 and reset account...then u can log in and add your info to mi account and upgrade to mui 8 if u want.
but removing mi account doesnt work on many mui 8 100% solution
Page generated in 0.25274 seconds with 8 queries
