06-12-2017, 06:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Delhi.India
Member: 652685 Status: Offline Sonork: 100.1594842 Thanks Meter: 45 | Mi Note Prime stuck on logo after format Operation log is here. Card found : xxxxxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.13 Operation : Identify [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 136DB716 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 93550FF766CCF9F4D388485592E96961 ID_BLOCK_L : 245FE1484DD4068F02EDA61F159896B5 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Xiaomi ProdName : ***** ProdModel : HM NOTE 1S Device : ***** AndroidVer: 4.4.4 Manufact. : Xiaomi SysPatch : KTU84P QLMxCPU : MSM8916 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 136DB716 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 93550FF766CCF9F4D388485592E96961 ID_BLOCK_L : 245FE1484DD4068F02EDA61F159896B5 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Now device can't be recovered by factory flash also. tried by QFIL and Fastboot but no sucess. |
