Old 10-18-2017, 16:24   #1 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
MI REDMI NOTE 4 PATTERN LOCK REMOVE Done
SUCCESSFULLY REMOVE PATTERN LOCK (MI REDMI NOTE 4)USB
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : 55238DC0
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 5E1B88A6161DC3963FB11F46DA48B087
ID_BLOCK_L : ED0B61C0172620FEF9408184F36BB7EA
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB
Boot Ok!
Brand : xiaomi
ProdName : mido
ProdModel : Redmi Note 4
Device : mido
AndroidVer: 6.0.1
Manufact. : Xiaomi
SysPatch : MMB29M
QLMxCPU : MSM8953
Done!
Elapsed: 00:00:23
Reconnect Power/Cable!
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:42
THANKS INFINITY-BOX TEAM
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 10-18-2017, 18:06   #2 (permalink)
Member: 2682035
Thanks Meter: 22
In which mode u connect...?
Sent from my Redmi 3S using Tapatalk
Old 10-18-2017, 19:00   #3 (permalink)
Member: 117432
Thanks Meter: 6
but when you connect to internet it locked again ?
Old 10-19-2017, 08:41   #4 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Bro,
u need special edl test point in pcb ....
only need normal usb cable.
Good Luck
Old 10-19-2017, 08:45   #5 (permalink)
Member: 2682035
Thanks Meter: 22
Thanks
Thanks bro....old models go edl mode with edl cable but new are not go with edl cable ...ok thanks but there is pronlem with under warranty phone when open watranty gone....
Old 10-19-2017, 08:59   #6 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Bro,
If you follow proper steps you will not get this problem and need too study software before using and you will success Gods Good Luck with you
Good Luck
Old 10-19-2017, 09:05   #7 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Bro,
If you use tweezer properly with tricks your warranty will not avoid
Good Luck
Old 10-19-2017, 17:24   #8 (permalink)
Member: 2682035
Thanks Meter: 22
Ok thanks a lot...i will care next time about it...
Page generated in 0.13542 seconds with 8 queries
