06-24-2018, 18:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | MiCl0ud remover file for CM2QLM the file is tested by me REDMI 4X (SANTONI) Here REDMI 4A (ROLEX) HERE Last edited by mifluvcute; 06-24-2018 at 18:49. Reason: add link |
The Following 9 Users Say Thank You to mifluvcute For This Useful Post: |
06-25-2018, 08:24 | #2 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! Enviado do meu SM-J100H através do Tapatalk |
The Following User Says Thank You to yuranc8 For This Useful Post: |
06-25-2018, 16:01 | #4 (permalink) |
Member: 1436243 Status: Offline Thanks Meter: 99 | try reflash with this firmware via emergency/edl mode *this is downgrade method,after sucess flash firmware, you can enter your old / new account do at your own risk |
The Following User Says Thank You to mifluvcute For This Useful Post: |
06-27-2018, 10:01 | #7 (permalink) | |
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
Flash via edl/emergency mode (cm2)/9008 mode Redmi 4a required testpoint to enter above mode (browse on the net) Or you can write manualy (by partition) by cm2 -> tab extra ~> memory tools | |
06-27-2018, 10:06 | #8 (permalink) |
Member: 1436243 Status: Offline Thanks Meter: 99 | Once again, anyone who have firmware to remove micloud, please share here. Cause all cm2 user will need it We know cm2 use their own solution (build from scratch) to fix the phone, and make software Cm2 team not buy solution from underground chinese market So as user we need to help each other to share and will be nice when it can help each other user. |
06-29-2018, 13:59 | #9 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | hello Quote:
Already Try with this version Firmware Code: mido_global_images_7.2.24_20170224.0000.00_7.0_global Not Solved. | |
08-10-2018, 21:37 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | I get the following error when trying to do flash/remove account lock from mi 4a and think it's related to drivers.Can you please share me correct driver for EDL mode?!!! Code: Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! |
