Hi Sir I Have One Qmobile A120 (MT6572) With Invalid IMEI
I Did These Steps
Flash With Factory Firmware (Same)
Flash With Bin File (Same)
Repair Basband + Repair IMEI + Write NV RAM (Still Same)
Possible Get Any Help To Fix This Phone ?
Here Is Phone Log
Card found: S/N 0B4F:0129
Chinese Miracle II [MTK module] v 1.29
Load File
File_Info : s4031a
FileVersion : MT6572
Load File Ok
Operation : Flash [ v1.29 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6572__QMOBILE__QMobile_A120__ALPS.JB3.MP.V1__And roid_4.2.2__20140410_103138.ispff
Wait for phone...
Phone found! [ 73 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048604A215576177
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048604A215576177
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : A120
ProdModel : QMobile A120
Device : A120
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
ISPFF ID : 6572 , TARGET ID : 6572
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write done , 3696 blocks sent
Done!
Elapsed: 00:09:24
Reconnect Power/Cable!
Operation : Write NVRAM [ v1.29 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[NVCheck] : BBID : MT6572 , NVID : MT6572
[NV] : Write Ok!
[Info] : NVRAM Repair on erased/damaged phone :
1. Fix Unknown BaseBand
2. Repair Security
3. Write NVRAM
Done!
Elapsed: 00:00:30
Operation : Fix Unknown BaseBand [ v1.29 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Reset Done!
Done!
Elapsed: 00:00:17
Operation : Repair Security [ v1.29 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 353615060857271
Set IMEI [01] : 353615065857276
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 73 ]
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:41
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[NV] : Write Ok!
2. Repair Security
3. Write NVRAM
Done!
Elapsed: 00:00:17
Reconnect Power/Cable! |
