Deepesh Sharma | 09-12-2015 08:00 | Micromax a065 preloader erased dead phone I HAVE MICROMAX A065 DEAD (PRELODER ERASED)
INFO Code:
Operation : Check / Read Info [ v1.29 ]
Wait for phone...
Phone found! [ 166 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D433034475854D140DFB12D
DA Stat : v4.2 on BBID : 0x8B
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D433034475854D140DFB12D
[eMMC] : FLASH_LEN : 0x00000000E6800000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:05
Reconnect Power/Cable! TRY TO REPAIR PRELODER Code:
Chinese Miracle II [MTK module] v 1.29
User selected Preloader file : preloader_huaqin71_cwet_i_kk.bin
Operation : Init Preloader [ v1.29 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SecCfg Passed , 1799
Flash Info :
FlashID [0] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON]
FlashID [1] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG]
BL : Storage supported by BootLoader!
Sending BootLoader ...
Preloader Sent , Init passed
PartTable Init Ok , Count : 14
All Done
Done!
Elapsed: 00:00:08
Reconnect Power/Cable! BUT SAME PRELODER ERASED TRY TO FLASH Code:
Operation : Flash [ v1.29 ]
======= Flash
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6571 , Project : huaqin71_cwet_i_kk , Storage : EMMC
Setting : AFF verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x0000000085060000
Flash Pre-Erase Done, time used : 00:00:06
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin71_cwet_i_kk.bin
PartCount : 0013
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:12
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:16
Update RomInfo done
Done!
Elapsed: 00:03:55
Reconnect Power/Cable! I WILL TRY BUT AFTER DO IT SAME Code:
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:05
Reconnect Power/Cable! NOW WHAT CAN I DO SET IN STILL DEAD MODE:( |
