03-13-2015, 08:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: INDIA, TamilNadu, ViLLuPuRaM
Member: 651056 Status: Offline Sonork: 100.1592669 not using now Thanks Meter: 201 | micromax a093 baseband unknown i have this phone in baseband unknown problem i try 2 flash by og tool but not clear (normal flash , full format flash) i searching for nv file for this model micromax a093 mt6582 if any one have this model nv file pls share for try or any other solution for this problem log detail Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580C780B6151A3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580C780B6151A3 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A093 ProdModel : Micromax A093 Device : A093 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : MMX_A093_SW_V8.0.8_HW_V1.0_20140609 Done! Elapsed: 00:00:09 Reconnect Power/Cable! br akk.vpm |
