09-17-2015, 13:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Copy Samsung GT-S7582 unable to connect any Solution???? Today i receive A Samsung GT-S7582 Copy for flash but unfortunately i am unable to connect it with Software. Nothing Appears in Device Manager what to do? Battery OK Charging Port is OK. Possible Reason: May be it would be flash with wrong Firmware earlier by another but for me its unable to connect.. Waiting for any solution or Suggestion... B/R Sheraz.... |
09-17-2015, 13:54 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, For start check which cpu phone has. You can also try to connect phone with volume keys pressed (one at a time or both)or with boot cable. Also check phone usb ways as sometimes phone shows charging but don't connect to pc due to usb tracks damaged or charging connector damage. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-17-2015, 14:16 | #4 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Both of You Thanks for the Suggestion, Furthermore, Should i go for open the Mobile and Short its GND+KOLO to get back Booting if the USB Jeck is OK? Waiting for reply... Sheraz... |
09-17-2015, 14:20 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | EVEN on MT6575/MT6577 this useless thing is not need. Enough hold both keys (VolUp+VolDown) with inserted cable and play 3-5 times with battery re-connect. In case of damaged VCHARGE line in CPU/Board - need hold powerOn after insert battery. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
09-17-2015, 14:47 | #6 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected JayDi And Passionate Boy I have done all the tricks as mentioned by you both but could not succeed to connect the mobile. Any further Suggestion? B/R Sheraz.. |
