09-18-2015, 17:40 | #16 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
i need a file dead by wrong firmware partition erased here is info Code: Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 112 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051566264ACB15D DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! | |
09-19-2015, 15:27 | #17 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
09-21-2015, 05:33 | #18 (permalink) | |
Code: Emails with collaboration links have been sent. here is also@ | |
09-21-2015, 09:31 | #19 (permalink) | |
i cant download file This file is currently set to private. | |
09-24-2015, 10:05 | #20 (permalink) | |
Insane Poster Join Date: Aug 2010 Location: India
Member: 1379392 Status: Offline Thanks Meter: 10 | Hey bro i want this file..micromax a106 mt6572 flash file.. My email [email protected] I need it urgently... Quote:
09-24-2015, 13:44 | #22 (permalink) | ||
will are trying to upload it in support area in "Micromax" folder today short time later | ||
The Following User Says Thank You to pradeep_kus For This Useful Post: |
09-27-2015, 13:19 | #24 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Hello@! all file uploaded to infinity support File is at server2 here - Index of flashfiles/Micromax/A106/ can download from there |
12-10-2015, 17:18 | #25 (permalink) | |
my wrong posting plz delete the post admin | |
12-19-2015, 03:14 | #26 (permalink) |
Registered User Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | Here is my phone log.. i need it's flash file(phone dead after flashing) 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 91 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040502A1A2A69153 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040502A1A2A69153 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
01-26-2016, 08:09 | #27 (permalink) |
Freak Poster Join Date: Oct 2010 Location: indore
Member: 1409652 Status: Offline Sonork: 100.1670588 Thanks Meter: 76 | here my log my id ( [email protected] ) Card found : S/N : 790C6B72 , v0129 Chinese Miracle II [MTK module] v 1.40 Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051641D6209B1A9 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
08-22-2016, 14:33 | #29 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2614851 Status: Offline Thanks Meter: 0 | I have a micromax a106 mt6572 phone. While flashing with official rom it shows target device not support this file. Now the phone is formatted even does not turn on. Please Give the flash file for solving this problem. |
08-22-2016, 18:06 | #30 (permalink) |
Member: 2614851 Status: Offline Thanks Meter: 0 | I have a micromax a106 mt6572 phone. While flashing with official rom it shows target device not support this file. Now the phone is formatted even does not turn on. Please Give the flash file for solving this problem. mail id- pintu660016(at)gmail(dot)com |
