04-22-2016, 14:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Micromax a107 need spd firmware Reading extended info ... Model Name : sp7731geaplus_dt_oversea Model Brand : Micromax Model Device: scx35_sp7731gea AndrVersion : 5.1 BaseBand CPU: SP7731GEA CompileDate : 27/11/2015 11:03:13 AM Project Ver : MMX_A107_SW_V0.1.5_HW_V2.0_040215 Model Ext : Micromax A107 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.16 ] |
04-22-2016, 14:15 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Here is link- https://docs.google.com/uc?id=0B4VAO...UNXb3NhSGJSR1U Credits to original uploader. Br. Infinity Box Support Team. |
04-22-2016, 14:49 | #3 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
thanks to cm2 support | |
06-17-2023, 20:50 | #4 (permalink) |
Freak Poster Join Date: Jan 2013 Location: layyah pakistan Age: 31
Member: 1869772 Status: Offline Sonork: 100.1615569 Thanks Meter: 10 | i need flash file.plz help Card found: S/N : 56xxxxxx , v0155 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Start at : [6/2/2023 / 9:42:36 PM] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Finish at : [6/2/2023 / 9:43:14 PM] Start at : [6/2/2023 / 9:43:18 PM] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 151 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [6/2/2023 / 9:43:51 PM] Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Start at : [6/2/2023 / 9:44:20 PM] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 151 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp7731geaplus_dt_oversea Model Brand : Micromax Model Device: scx35_sp7731gea AndrVersion : 5.1 BaseBand CPU: SP7731GEA CompileDate : 11/26/2015 7:04:42 AM Project Ver : MMX_A107_SW_V0.1.5_HW_V2.0_040215 Model Ext : Micromax A107 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:30 Reconnect Power/Cable! Finish at : [6/2/2023 / 9:44:50 PM] Start at : [6/2/2023 / 9:44:58 PM] Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 151 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Test flow passed! Test flow #1 ... Test flow passed! Test flow #2 ... Test flow passed! Test flow #3 ... Test flow passed! Test flow #4 ... Test flow passed! Test flow #5 ... Test flow passed! Finalize Ok! Test passed successfully! Elapsed: 00:00:22 Reconnect Power/Cable! Finish at : [6/2/2023 / 9:45:20 PM] |
06-17-2023, 20:50 | #5 (permalink) | |
Member: 1869772 Status: Offline Sonork: 100.1615569 Thanks Meter: 10 | Quote:
