-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Micromax A110 Flashing error (http://forum.gsmhosting.com/vbb/f296/micromax-a110-flashing-error-2240535/)
vishal110094 07-05-2017 08:39
Micromax a110 MTK 6577 conectivity issue
flashing failed with cm2 ( with battery and w/o battery ) but done with SP flash tool
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:16
Reconnect Power/Cable!
Finish at : [7/5/2017 / 12:34:23 PM]
Start at : [7/5/2017 / 12:47:22 PM]
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x0F
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A14404CC10B9
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xE9D3EF6B7C6443F0F287C504E5A1B215
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000008000
Erase Error! Something went wrong!
Operation Failed
Elapsed: 00:00:40
Finish at : [7/5/2017 / 12:48:01 PM]
Start at : [7/5/2017 / 12:48:09 PM]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:12
http://postimg.org/image/4cl83ml6t/
Page generated in 0.12997 seconds with 5 queries
