01-22-2016, 16:46 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | micromax a116 dead Chinese Miracle II [MTK module] v 1.40 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 204A0190594E4958D8A11648AB103B9C DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 Error : DA init Failed! Error code : 0x5 LErr : 1F6A0000 Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
01-22-2016, 17:45 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Same here. Something wrong with phone RAM memory. If it embded in eMMC - then, probably, resolder will help. If it separate - then need resolder or change it. |
