07-25-2015, 17:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: PAKISTAN/MULTAN
Member: 242838 Status: Offline Thanks Meter: 83 | MicroMax A120 FIrmware or NVRAM Requaired i tried to repair security its said Nvram Damaged Kindly help me in this Matter here is Log, Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 911367107215460 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 911367107965965 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:07:41 Reconnect Power/Cable! Thanks in Advance INFINITY TEAM |
07-25-2015, 18:27 | #4 (permalink) |
Member: 242838 Status: Offline Thanks Meter: 83 | I have flash it many time here is log with CM2 permanet 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040504A14D9471C1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040504A14D9471C1 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Reconnect Power/Cable! |
07-25-2015, 20:02 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I have no idea what you done and how. I have no idea what is "dead". I have no idea why you trying repair imei if it dead. Repair mobile first to WORKING state WITH ALIVE BASEBAND ( Settings - > About ) Then repair security. |
07-25-2015, 20:09 | #8 (permalink) | |
Member: 242838 Status: Offline Thanks Meter: 83 | Quote:
I tried to swicth it on but its not switch On i surprised fone Dead Thats My Sad Story Last edited by crazygenius3; 07-25-2015 at 20:15. | |
05-31-2018, 17:36 | #10 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054014 Status: Offline Sonork: asishpin2 Thanks Meter: 0 | Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040401A6D881A03B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040401A6D881A03B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x15CC4D34D679FE76E11599844E463762 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! i just repair IMEI, this problem is show ...any one know this problems solution....adv thanxxxxxxxx |
