Old 03-05-2016, 09:12   #1 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
once again spd bolt t5 dead after flash ?
please infinity team i m reporting not to blaming you
some days before bolt t480 was killed after flash
and mr jaydi was saying that its hardware problem
and now today bolt t5 ware woking conditiong only virus
i flshed with the file taken form working phone
and now its totally dead
now what should i do ???
customer is demanding ok set
what should i do now
stuck in the middle
Card found: S/N : 8E493392 , v0130
Chinese Miracle II [SPD module] v 1.15
Infinity SC Firmware Detected
FW Size : 366 MiB
Load Ok!
Operation : Flash [ v1.15 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Write Data ...
Write Data Ok!
Write FSImage : prodnv_b256k.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7715_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : CP2._CP2_WCN_14C_W15.14_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_320x480.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_320x480.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system_b256k.img
Write Data ...
Write Data Ok!
Write FSImage : cache_b256k.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Write FSImage : userdata_b256k.img
Write Data ...
Write Data Ok!
Elapsed: 00:02:47
Reconnect Power/Cable!
Old 03-05-2016, 09:17   #2 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
you dont use app manager ?
Old 03-05-2016, 09:27   #3 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
after using aap namanger set was still slow
every thing was working in slow motion
there for i flashed the phone
Old 03-05-2016, 09:40   #4 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
thanks my problem solved with other tool
after flash set was dead
i format the set and no use
then i did format with *****l box thanks *** set is alive again and woking good
please please infinity team fix this
Old 03-05-2016, 09:59   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
http://forum.gsmhosting.com/vbb/f296...y-box-2061231/
Seems as it your karma or bad luck.
Next time try find OK file or read.
Also check head.sys and hands.sys , probably they are curved well.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 03-05-2016, 10:17   #6 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
you think only you have head.sys and hands.sys and only yours are corved well
you think every one in the world is headless.sys handles.sys and there's are not curved
well and they need to go to good doctor like you to treat them and to give
them medicine
aaaakkkhhhhhhh
Page generated in 0.13777 seconds with 8 queries
