12-04-2015, 10:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: ONLY WITH YOU Age: 39
Member: 314847 Status: Offline Thanks Meter: 102 | Micromax A310 Unkonw basbend Raiper ? 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND : Error : DA init Failed! Error code : 0x4 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Any idea what problem is ? |
12-05-2015, 09:43 | #3 (permalink) |
Member: 314847 Status: Offline Thanks Meter: 102 | can we check which DA It has i have one onether device which has same problem Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
