Old 12-21-2014, 13:22   #1 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,027
Micromax A47 Dead
Micromax A47 Dead
Custome Says Its Suddenly Set Become Dead
I try to short kcolo+ gnd but still Preloader Status : Not active (Erased)
Need Help
Operation : Check / Read Info [ v1.07 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
DA Select done , sending
NAND_ID : 00AD00BC00900055005600AD00BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C
[NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000
[NAND] : FLASH_LEN : 0x00000000
INT RAM    : 0x00000000
EXT RAM    : 0x00000000
BOOT TYPE  : DONE
SOC VERIFY : 00
Boot Ok!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:02:12
Reconnect Power/Cable!
Old 12-21-2014, 13:33   #2 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,027
Same Model Just to Check
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
[NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x10000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
Old 12-21-2014, 13:41   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,182
Hello, make flash read, please, and upload dump somewhere.
Old 12-21-2014, 14:05   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,022
Hello,
Original firmware can do the needful for you? Or need only CM2 read file?
Br.
Old 12-21-2014, 14:24   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,182
Hello, Will be good any.
Factory just more light weight
Old 12-21-2014, 14:32   #6 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,027
Hi Sir
In my first post a47 is dead need help to revive it
Set Preloader Status : Not active (Erased)
How to solve it [i think it H/W]
there is any way to check sw or hw
in my second post set is different a47 it have lcd problem just i check it if this can help us
Here og firmware:-https://drive.google.com/uc?id=0BwxV...UJ0eG10NWR5ZVU
Source for firmware: androidxda
Page generated in 0.24643 seconds with 7 queries
