07-09-2010, 18:01 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
07-22-2010, 21:09 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx please note that this method is valid only for MT62xx phones. so please check CPU type first! |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
8810 pinout?? | timitiz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-11-2012 11:10 |
Please Help, Pinout of N8810 | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-30-2010 15:53 |
8810 pinouts for dejan flasher !?!?!? | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-03-2001 04:39 |
8850 pinouts | MDR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-30-2000 01:23 |
