Old 09-05-2015, 08:37   #1 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,212
micromax canvas gold unable to reset privacy code
micromax canvas goild unable to reset privacy code (user data safe)
Operation : Reset Privacy Lock [ v1.28 ]
Wait for phone...
Phone found! [ 101 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 15010042574243335202972BB68781CD
DA Stat : v4.2 on BBID : 0x8A
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : R3CBW
[eMMC] : FLASH_CID : 15010042574243335202972BB68781CD
[eMMC] : FLASH_LEN : 0x0000000747C00000
INT RAM    : 0x00020000
EXT RAM    : 0x80000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Privacy Lock not set!
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Old 09-05-2015, 09:30   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,001
It is Privacy lock?
Does patternLock read ok?
Try. If FS ecnrypted - then you can't use "UserData Safe" method.
Old 09-05-2015, 11:32   #3 (permalink)
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,212
Originally Posted by JayDi View Post
It is Privacy lock?
yes i read pattern sucessfully
Successfully unlocked/repaired phones by Infinity-Box
but i need safe all data custmer gave me extra cost for that
Old 09-05-2015, 11:37   #4 (permalink)
JayDi's Avatar
Member: 462970
@Deepesh_Sharma , make factory FW read from it.
Connect in PM with me after. Will give you instructions to check all things.
Old 09-05-2015, 11:46   #5 (permalink)
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,212
now i get password maunaly
you need factory firmware for improve cm2?
Old 09-05-2015, 11:48   #6 (permalink)
JayDi's Avatar
Member: 462970
No, I need acess to that phone remotely for 5-10 minutes. Otherwise - there is no reason to try add something.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.25603 seconds with 7 queries
