03-08-2016, 16:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | need a little attention from experts art at : [3/7/2016 / 7:20:52 PM] Operation : Flash [ v1.42 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A1B6F441B3 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A1B6F441B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 70C9702F775DB3B38222DDC0A5CBFE91 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_we_b2b_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4014 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_we_b2b_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:37 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:12 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:13 Reconnect Power/Cable! Finish at : [3/7/2016 / 7:24:05 PM] Start at : [3/7/2016 / 6:03:20 PM] Operation : HW Test [ v1.42 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A1B6F441B3 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A1B6F441B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 70C9702F775DB3B38222DDC0A5CBFE91 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040500A1B6F441B3 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Start at : [3/7/2016 / 6:04:12 PM] Operation : HW Test [ v1.42 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A1B6F441B3 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A1B6F441B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 70C9702F775DB3B38222DDC0A5CBFE91 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:13 Reconnect Power/Cable! Finish at : [3/7/2016 / 6:05:26 PM]Start at : [3/7/2016 / 6:06:38 PM] Operation : HW Test [ v1.42 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A1B6F441B3 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A1B6F441B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 70C9702F775DB3B38222DDC0A5CBFE91 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 4045 mV All Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [3/7/2016 / 6:06:48 PM] used latest file which i found c345b016 |
03-08-2016, 16:18 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | (1) Download-firmware -this code file 100% ok test code file Y600-U20V100R001C435B012 (2) http://www.mediafire.com/view/k4hip4...atter_file.rar Password = huawei5 Last edited by GSM KPK; 03-08-2016 at 16:25. |
03-09-2016, 11:05 | #3 (permalink) | |
Member: 714116 Status: Offline Thanks Meter: 48 | Quote:
thanks but not solved my problem. same hang on logo | |
