Old 04-11-2016, 05:53   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,340
Micromax D303 Complete SP Unlock :)
That phone became locked after factory reset.
Solution : read SP codes.
Operation : SP Unlock [ v1.45 ]
Mode : Read Codes
Wait for phone...
Phone found! [ 63 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 110100303034474530012348CAAC923B
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 110100303034474530012348CAAC923B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : E64CE88CDB78B0A57DBE7A8647C56333
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Slot[1] SIMLock Info :
[1] Level , [Locked] : True , [Count] : 255 , [Spc] : 2304 , [UnlockCode] : 86095550
[2] Level , [Locked] : False
[3] Level , [Locked] : False
[4] Level , [Locked] : False
[5] Level , [Locked] : False
[6] Level , [Locked] : False
[7] Level , [Locked] : False
Slot[2] SIMLock Info :
[Info] : Additional SP Codes :
NCK[1] : 01959203331678
NCK[2] : 01959203331678
======== Info
If phone not asking code :
1. Open MTK Setting Menu : *#*#3646633#*#*
2. GoTo : SimMELock->Network->Personalization->Unlock
3. Enter code
If Code not accepted - use "SP Direct Unlock" mode
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Enter additional codes. I unlock only SIM1 ( not have free second sim card )
Make factory reset :
Operation : Format FileSystem [ v1.45 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:25
Power on phone. Insert SIM. Check after :
Mode : Read Codes
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[1] Level , [Locked] : False
======== Info
3. Enter code
Done!
Elapsed: 00:00:12
Phone will not relock anymore after factory reset , wipe and etc
The Following 10 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.16659 seconds with 7 queries
