Old 02-29-2016, 11:30   #1 (permalink)
Member: 2298369
Thanks Meter: 440
Micromax e481 flash sucessfully but show tool image flailed
I FLASHED MICROMAX E481-
======================== Start =========================
2/28/2016 / 5:46:20 PM
Scatter Load Ok , BaseBand : MT6753 , Project : l5460 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Start at : [2/28/2016 / 5:47:03 PM]
Operation : Flash [ v1.41 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065324741075707053134D300
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A48414732650507570700D3A231
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : DCA65A827DA66BB1DAB9705016A17E9C
INT RAM : 0x00020000
EXT RAM : 0xC0000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6753 , Project : l5460 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3716 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x0000000142380000
Flash Pre-Erase Done, time used : 00:00:05
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_l5460.bin
Preloader Sent , Init passed
PartCount : 0016
Update PMT by user request
Repartition Done!
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:06:19
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:03:01
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:09:41
Reconnect Power/Cable!
Finish at : [2/28/2016 / 5:56:43 PM]
IT COME FOR ANTI THEFT LOCK I TRIED TO DIRECT BUT NOT SUCCESS, THEN I FORMAT WITH SP TOOL THEN FLASH BUT HANG ON MICROMAX WITH IMAGE TOOL DL FAILED, AFTER THAT I TRIED WITH CM2 BUT SAME PROBLEM PLZ SOLVE THIS BUG. THEN I RECOVER IT FROM OTHER TOOL.
Old 02-29-2016, 11:37   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
I not see any problem or error in log.
If face such problem again with another phone - let me know.
Old 02-29-2016, 12:13   #3 (permalink)
Member: 2298369
Thanks Meter: 440
Yes i put log here for this reason, cm2+sp tool (i load file+tool from micromax ftp) both done flashing complete but after that set hang on micromax in side show tool dl image failed.
Old 02-29-2016, 12:35   #4 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
flash with sptool with da dll checked on setting
Old 02-29-2016, 12:52   #5 (permalink)
JayDi's Avatar
Member: 462970
Can't say anything useful yet. Will check about that.
CM2 also have FixDL option as last chance.
Old 10-26-2016, 21:40   #6 (permalink)
Member: 618025
Thanks Meter: 39
Hi
Need backup file for this model
Sent from my LS-5503 using Tapatalk
Old 10-26-2016, 21:42   #7 (permalink)
Member: 618025
Thanks Meter: 39
Any one have this file can u please upload for me I can't file ver 18 file anyways if any one this this file upload for me
Thanks in advance
Old 10-27-2016, 08:18   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Thanks in advance
Hello,
Post extended info log from software.
Br.
Infinity Box Support Team.
Old 10-27-2016, 09:24   #9 (permalink)
Member: 618025
Thanks Meter: 39
Need This file bro I already flash all ver but mobile have problem hang on logo
slow charging / boot fail / phone memory low ots of problem from another flash file
I try All Ver from Support
This file is read backup from phone when phone arrived in shop
phone is hang on logo before flash
MT6735__Micromax__Micromax_E481__E481__5.1__ALPS.L 1.MP3.V2.21_TINNO6753.65U.G_P60
Old 10-27-2016, 09:28   #10 (permalink)
Member: 618025
Thanks Meter: 39
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 484A019065324741896C0705A54C32AD
DAgent sent , init HW now
[eMMC] : FLASH_CID : 90014A484147326505076C89AD32A2A5
DEV RID : 0x561EB6962F4A46413A63C50C32A47558
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Micromax
ProdName : E481
ProdModel : Micromax E481
Device : E481
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : ALPS.L1.MP3.V2.21_TINNO6753.65U.G_P35
SECURITY :
IMEI_SW [1] : 911457550078117
IMEI_SW [2] : 911457550328611
BTMAC Addr : BC4434038286
WiFi MAC : BC44340320AC
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V26_P23_1_lwg _n
EXTRA :
LCD : Not info available
LCD Res : 1920x1080
TOUCH [0] : GT1XX
CAM [0] : s5k3m2_mipi_raw
CAM [1] : ov5648_mipi_raw_darling
CAM [2] : ov5648_mipi_raw_sunwin
MODEM : l5460_lwg_modem_b18_lteb3b5b40_mmx
LOCALE : en_US en_IN hi_IN mr_IN bn_IN kn_IN te_IN ta_IN ml_IN gu_IN pa_IN or_IN de_DE fr_FR es_ES in_ID it_IT ms_MY pt_BR vi_VN tr_TR ar_EG zh_CN fa_IR ar_EG es_ES fr_FR ru_RU ro_RO my_ZG
Done!
Elapsed: 00:00:09
Old 10-27-2016, 13:18   #11 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
What version written at back sticker?
Make Flash IC Test.
After try THIS firmware.
Br.
Old 10-28-2016, 15:34   #12 (permalink)
Member: 618025
Thanks Meter: 39
Sent from my iPhone using
Old 10-28-2016, 16:27   #13 (permalink)
Member: 618025
Thanks Meter: 39
Hw ver 1.1 sw ver 10
Old 11-08-2016, 18:32   #14 (permalink)
Member: 618025
Thanks Meter: 39
Any one have read file for this phone
Page generated in 0.23233 seconds with 9 queries
