10-21-2016, 11:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Micromax Q300 unable to service Micromax Q300 unable to service, even after selecting all the boot with AltLdr. Logs: Operation : Check/Read Info [ v1.22 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Here it is SVC mode info: Code: 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_Pike_W15.18_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 04-14-2016 16:11:56 Phone Security Info : IMEI [1] : 911507******** IMEI [2] : 911507******** BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.982 V Done Reconnect Power/Cable! |
10-21-2016, 13:29 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try with Crev cpu selection, with/without AltLDR option. Also try selecting original pac file, post result. Br. Infinity Box Support Team. |
10-22-2016, 08:34 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Br. Infinity Box Support Team. | |
