01-12-2017, 07:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: India Age: 39
Member: 78717 Status: Offline Thanks Meter: 18 | Micromax Q340 still dead after flashing any solution ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507D8A1252F7261 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507D8A1252F7261 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x1B97FA7D99C1A7DC0D836B37D7B48BF3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s5222 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000C1E00000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark passed Sending Preloader ... Use : preloader_s5222.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:08:40 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:28 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:47 Reconnect Power/Cable! |
01-12-2017, 09:12 | #3 (permalink) |
Member: 78717 Status: Offline Thanks Meter: 18 | rest report Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507D8A1252F7261 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507D8A1252F7261 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x1B97FA7D99C1A7DC0D836B37D7B48BF3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read error! Erased or damaged FlashIC?! Force eMMC test by user request Processing Miscellaneous test MSC : BatteryLevel : 2982 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , e1G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A48384731650507D8A1252F7261 [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:46 Reconnect Power/Cable! |
02-11-2017, 14:21 | #5 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507D5A11CFA82F3 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507D5A11CFA82F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD51C16D70E8AC0BF95C819C5860DEAF0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read error! Erased or damaged FlashIC?! Force eMMC test by user request Processing Miscellaneous test MSC : BatteryLevel : 3579 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , e1G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A48384731650507D5A11CFA82F3 [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:55 Reconnect Power/Cable! |
02-11-2017, 14:27 | #6 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
Unfortunately your eMMC is gone to ReadOnly. Need to change it. | |
The Following User Says Thank You to chandanps18 For This Useful Post: |
