01-25-2017, 16:31 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Check BaseBand, if baseband alive repair imex with CM2:Permanent mode. If baseband unknown write good firmware to phone. Br. Infinity Box Team. |
01-27-2017, 17:10 | #3 (permalink) | |
Junior Member Join Date: Oct 2016
Member: 2633621 Status: Offline Thanks Meter: 1 | Quote:
BASEBAND GOOD CM2:PERMANENT MODE I TRY Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! | |
01-28-2017, 08:51 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Write good NVRAM to phone and try to repair again. And next time post logs if you want some help. Br. Infinity Box Team. | |
02-04-2017, 16:33 | #5 (permalink) |
Member: 2633621 Status: Offline Thanks Meter: 1 | Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050742F3692F62C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050742F3692F62C7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC2286D70CD796571E198229547136389 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
