Old 07-05-2017, 18:21   #1 (permalink)
Member: 2636476
Thanks Meter: 50
micromax q372 emmc change then error
micromax q372 dead emmc problem then i try to change emmc then try to flash with sp tool error then try to check in cm2 show this error
is it ic is damged or any other problem i also removed volume keys but still same
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 65646F4D204D4F521281000002400153
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:36
Reconnect Power/Cable!
Old 07-07-2017, 13:53   #2 (permalink)
Member: 2636476
Thanks Meter: 50
no replay from infinity team
Old 07-07-2017, 20:32   #3 (permalink)
Member: 794019
Thanks Meter: 29
usually its an EMMC faulty. but try to load scatter first before reading info see if that works. if its not working then you should check the EMMC again, check if the boot size is correct, boot from partition 1 (ROM 2), and check if the CID matches its preloader.
Old 07-07-2017, 21:06   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
Bad soldering.
Old 07-08-2017, 08:32   #5 (permalink)
Member: 1778254
Sonork: sornork id
Thanks Meter: 35
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:36
is 2nd emmc?
eMMC Flash : 65646F4D204D4F521281000002400153 because over heat on remove/replease
if CID 0000000000xxxxxxxx
but dram detect bad soldering
if cid detect ram dot detect ram not good soldering
cm2 able detect empty emmc w/o preloader
Old 07-10-2017, 15:31   #6 (permalink)
Member: 2636476
Thanks Meter: 50
ok now i try to change again emmc
thnx for replay all
Page generated in 0.24638 seconds with 7 queries
