Old 04-05-2011, 12:17   #1 (permalink)
er.shivam's Avatar
Member: 1158702
Sonork: http://www.zentex.in/
Micromax Q5 Dead After Flash
Before Flashing Set hang On Opening Camera But After Flashing handset Dead
Log Here
COM2 [VCP0] selected
module v3.62
Device: Micromax-Q5
Checking data, wait...
Action: write flash NAND
write: Firmware
Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_08_2010-01-09_En_ver2.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
firmware patch (sp-lock #1)...
not required
firmware patch (sp-lock #2)...
not required
nfi area detection...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_08.bin
nfi area detection (3 cores) finished: Ok
"format ffs" active
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E521_MP_F1_IN_MMX_05.08
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is valid
startup code area #1 detection done
rom info ver: 07
sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN
project-id: E521_MP_F1_IN_MMX_05.08, 0556E59E
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
New firmware found (v.3.62, database date: 13.01.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._TINNO35_09A _PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_08.BI N_9EE55605_.rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _IN_MMX_05_08.BIN_9EE55605_.rpl
warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605
Unknown firmware found (v.3.62, database date: 13.01.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Format (HW_STORAGE_NAND)...
Disconnect...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_08__system_log_20110405-163922.B4X.bin
Finished, time used: 43 min 28 sec
Remove/Install battery now !
Pls Help
Old 04-05-2011, 14:57   #2 (permalink)
ramrajbhopal's Avatar
Member: 768205
micromax mostly dead after flash
Old 04-05-2011, 15:05   #3 (permalink)
gulab_sam's Avatar
Member: 759661
try this fly for flashing hope ur problem solve download infinity site
Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_I N_MMX_15_13_2010-06-25_En.B4M.bin
try and post result
Old 04-08-2011, 12:14   #4 (permalink)
er.shivam's Avatar
Member: 1158702
Infinity team help.......
try and post result
Brother when i flash with this file my phone switch on but hang on first screen & wrong key working like when i press clear button working 0 button & when i press call button working 7 button
please help
Old 04-08-2011, 12:44   #5 (permalink)
Member: 536734
pls help me brother RAGA RQ 101 ki flash file dedo mujhe bahut jaroorat hai
Old 04-08-2011, 12:56   #6 (permalink)
dapinderjit's Avatar
Member: 145082
u flahed the phone with which box br...
Old 04-08-2011, 13:48   #7 (permalink)
er.shivam's Avatar
Member: 1158702
I am using Infinity Box
Old 04-08-2011, 14:51   #8 (permalink)
er.shivam's Avatar
Member: 1158702
My Problem Solve successfully By Mr.Omegasekar He give me process
I Have done Step By Step...
1.1st Whole Erase Flash
2.Flash With New File with Support Area..
& Then My Set Working Normally
Thanks Mr.Omegasekar
Old 04-08-2011, 14:54   #9 (permalink)
omegasekar's Avatar
Member: 328758
Sonork: 1603668
haiiiiiiiiiiiiiiiiii
thanks bro
i really thank u
Old 04-08-2011, 14:55   #10 (permalink)
er.shivam's Avatar
Member: 1158702
Log Here
module v3.62
Device: Micromax-Q5
write: Firmware
Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_09_2010-03-01_En.B4M.bin
skip: Customization
skip: Eeprom/ffs
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_09.bin
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
detect ffs...
detect sec ro...
detect NAND info...
warning: header is empty: probably flash chip completely erased
warning: can not detect header
nfi area detection (0 cores) finished: failed
warning: ffs can not be detected
TCL-ID detection...
===> done
startup code area #1 calculation...
startup code area #1 fixed
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 7 min 48 sec
Old 05-15-2013, 06:55   #11 (permalink)
Member: 1892801
Q5 - Download - 4shared - junaid alam
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.39186 seconds with 11 queries
