11-11-2011, 08:00 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | micromax q5 no power error : > Uploaded with ImageShack.us if i format with 6228-6253 nand than show this . logs : > Code: COM15 [VCP0] selected module v3.26 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521_MP_F1_IN_MMX_05.12 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_12.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_12.BIN project-id: E521_MP_F1_IN_MMX_05.12, A3AA2E52 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done file saved: C:\Program Files\ChineseMiracle\backup_security\TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_12__system_log_20111111-122507.B4X.bin Finished, time used: 1 min 0 sec Remove/Install battery now ! |
11-13-2011, 23:59 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if phone is dead- it must be flashed by following software version: flashfiles/Micromax/Q5/Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_12_2010-06-25_En.B4M.bin |
11-27-2011, 10:17 | #5 (permalink) | |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
befor that i try many flash file but problem same still. after all i flash with this flash file as u mention ur befor post. thanxx again working flash file: > Code: Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_12_2010-06-25_En.B4M.bin Code: COM2 [VCP3] selected module v3.75 Device: Micromax-Q5 Checking data, wait... Action: write flash NAND write: Firmware Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_12_2010-06-25_En.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_12.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_12.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Disconnect... done Finished, time used: 37 min 24 sec Remove/Install battery now ! screen shot : > Uploaded with ImageShack.us | |
The Following 2 Users Say Thank You to royal_electronics For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Dejans Flasher Problem with 6150, NO Network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2001 22:39 |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
