Old 09-06-2010, 12:05   #1 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 778
micromax Q55 pinout and FW
Hi,
Here is all for micromax twinkle
Pin-finder pin-out
CPU: MT6235
result: Rx:4 Tx:5
time required: 18 sec
Trying to Power-On...
Power On !
Firmware read by selecting Q5 in "MModule_v3.56.exe"
module v3.56
Device: Micromax-Q5
Checking data, wait...
Action: read flash NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (460800)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E580_MP_F1_IN_MMX_05.13
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_IN_ MMX_05_13.bin
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: can not read memory: 0FB1:S_FT_NAND_READADDR_NOT_PAGE_ALIGNMENT
error: can not read area #1 (00062400-000663FF): 0FB1:S_FT_NAND_READADDR_NOT_PAGE_ALIGNMENT
startup code area #1 detection failed
rom info ver: 07
sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_IN_M MX_05_13.BIN
project-id: E580_MP_F1_IN_MMX_05.13, C673443E
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: 2nd [protected] type, 1 record(s)
TCL-ID is absent
===> done
area size: 64Mb
number of areas/bytes to read: 1:04000000
The Following 2 Users Say Thank You to srkhan For This Useful Post:
Old 09-06-2010, 12:07   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,376
Hello,
Please, read full flash (or firmware) once again with ChineseMiracle v3.22
It's important tom read flash with ChineseMiracle v3.22 due to this phone contain hardware that can be read well with this version only.
Please, post here operation log for reading with CM v3.22
Thank you !
Old 09-06-2010, 13:24   #3 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 431
please provide full flash it will help full
Old 09-06-2010, 13:38   #4 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 778
Cant Read with "ChineseMiracle v3.22"
==== [9/6/2010 3:14:24 PM] ====
COM9 [VCP0] selected
module v3.22
Device: Autodetect 6205-6239 NOR
advanced flash detection disabled
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot Off
chip: 0000:0000:0003
status: FF
high speed boot Off
boot packet size: 0400
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 21 sec
Remove/Install battery now !
Old 09-06-2010, 14:14   #5 (permalink)
Member: 130995
Hello,
Please, select "NAND" model in Chinese Miracle !
Thank you !
Old 09-06-2010, 15:43   #6 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 778
==== [9/6/2010 7:27:24 PM] ====
module v3.22
Device: Autodetect 6228-6239 NAND
Action: read firmware NAND
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect NAND info...
TCL-ID detection...
error: unexpected answer:
startup code area #1 is valid
startup code area #1 detection done
rom info ver: 07
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
New firmware found (v.3.22, database date: 02.09.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 32Mb
number of areas/bytes to read: 1:02000000
file saved: C:\Documents and Settings\Administrator\Desktop\TINNO35_09A_PCB01_G PRS_MT6235B_S01.E580_MP_F1_IN_MMX_05_13__firmware_ 20100906-193951.B4M.bin
Disconnect...
done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T INNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_IN_MM X_05_13__system_log_20100906-194002.B4X.bin
Finished, time used: 12 min 38 sec
The Following User Says Thank You to srkhan For This Useful Post:
Old 09-06-2010, 16:16   #7 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 778
Old 03-04-2011, 15:53   #8 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
file not found///deleted....
The Following User Says Thank You to .::RanjitSinh::. For This Useful Post:
Old 03-04-2011, 22:55   #9 (permalink)
Member: 130995
Please, download Q55 file from Infinity-Box support area.
Old 03-30-2011, 13:46   #10 (permalink)
Temporary banned !!
Member: 374340
Sonork: 1604089
Thanks Meter: 26
Q55
u can select direct now
Old 01-08-2014, 12:07   #11 (permalink)
Member: 1801908
Thanks Meter: 11
micromax x55 format after dead
micromax x55 dead after format
CPU.6236 MTK
THANKU
Old 08-14-2015, 07:02   #12 (permalink)
Member: 2367936
Need micromax x55 bin file please...
Old 08-14-2015, 07:45   #13 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,010
Hello,
Download from support area.
Br.
Old 09-28-2015, 05:12   #14 (permalink)
Member: 2367936
i need link, please. it urgent
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware Repair 2 07-23-2013 03:41
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 20:18
Page generated in 0.44860 seconds with 9 queries
