07-29-2015, 06:07 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Micromax S300 SPD 7715 Format disable Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : S300 Model Brand : Micromax Model Device: S300 AndrVersion : 4.4.3 BaseBand CPU: SCX15_SP7715EA CompileDate : 1426494825 Project Ver : MMX_S300_SW_1.5.3_HW_1.0.0_20150309 Model Ext : Micromax S300 Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Read NV [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Read NVM Part #1 Part Ok Read NVM Part #2 Part Ok Saved to : C:\InfinityBox\CM2SPD\phdata\gcnv\CX_SPDNV_Micromax S300.spnv Elapsed: 00:00:49 Reconnect Power/Cable! Code: Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Format disabled for eMMC for now! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following User Says Thank You to situ_saraf For This Useful Post: |
07-29-2015, 07:30 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | us og tool and file or og file and flash with cm2spd check your pm for flasher + file + imei tool all in one link sent |
The Following User Says Thank You to kariakala For This Useful Post: |
10-25-2016, 05:12 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
