07-12-2010, 07:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Micromax X1i+ dead after flash? COM4 [VCP0] selected module v3.45 Device: Micromax-X1i+ Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6770:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6532_V 1409.BIN project-id: 220612_6532_V1409, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6532_V 1409.BIN detecting firmware build... ........................... firmware build: q220612_6532_V1409TIANYU23_08A_PMWY_HW2009-10-2416-36 detecting product-id... ................................ done detecting languages... ......................... language parameters detected detected languages: En Hi Finished, time used: 53 sec Remove/Install battery now ! |
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
07-12-2010, 15:22 | #2 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Hello! Infinity team here is I am uploanding fullflash link. RapidShare: 1-CLICK Web hosting - Easy Filehosting |
07-12-2010, 23:32 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Hello, is it full flash backup BEFORE any operation or AFTER flash ? Did you tried to flash phone with this file from support area ? Micromax-X1i_TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_65 32_V1416_2009-10-30_En_Hi.B0M.bin |
07-13-2010, 07:10 | #5 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Sir, here is flashing logs plz help... COM4 [VCP0] selected module v3.49 Device: Micromax-X1i+ Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Micromax-X1i_TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_65 32_V1416_2009-10-30_En_Hi.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Micromax-X1i+_ffs_01.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6770:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6532_V 1416.BIN project-id: 220612_6532_V1416, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 208848FFFFFFFF:20884800000000 Write: Firmware Area: Eeprom/ffs flash: 208848FFFFFFFF:20884800000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 208848FFFFFFFF:20884800000000 Finalization Done Finished, time used: 1 min 23 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
07-13-2010, 10:45 | #6 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Quote:
If phone can not power-on after original flash backup - you have a reason to check phone hardware. | |
07-13-2010, 13:30 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | What is this ? http://forum.gsmhosting.com/vbb/f296...7/#post6074034 |
07-14-2010, 07:58 | #9 (permalink) | |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
07-14-2010, 13:39 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | I understand noting... What was your file from your post #2 ? Is it original backup from your phone or not ? Also, pls, tell me, where can I get "original backup from your phone" if you are the only person who has your phone... How can I read flash from your phone and send it to you ??? |
07-15-2010, 09:27 | #12 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Sir, I got what is the problem with my phone.. I need this one software " TBG2206A P2-007 PCBA-24 S/W1543 " means software version is 1543. I was written this software version Micromax-X1i+_TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6 532_V1416__fullflash_part_1_of_1_20100715-124737.B0M plz if you have upload this software version Micromax-X1i+_TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6 532_V1543__fullflash_part_1_of_1_20100715-124737.B0M |
07-15-2010, 15:22 | #13 (permalink) | |
All files that we have already uploaded in support area. We never hide any files from our dear users and we upload all that we have in support area to give everything what we can to our dear users. | |
07-15-2010, 16:31 | #14 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | NO no no Sir, I am not saying that file is hiden in support area. Sir, this is new file that I need. This is newer version phone from Micromax x1i+. Sir, I found a stiker at PCB of this phone there is printed this like " Version:TBG2206A P2-PCBA-24 S/W1543 " |
07-15-2010, 22:08 | #15 (permalink) | |
This file is not exist in support area yet. It will be good if somebody can read full flash from the same good working phone and send full flash (or RapidShare: 1-CLICK Web hosting - Easy Filehosting link) backup file to [email protected] so we will be able to prepare and upload good working files in support area for all users. | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
