Old 02-22-2011, 14:20   #1 (permalink)
totalmanish's Avatar
Member: 336192
Thanks Meter: 51
micromax x265 imei
unable to write imei in micromax 265 any new method
Old 02-22-2011, 15:21   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,856
What is the problem exactly?
Have you tried with mode1,2,3?
You can also try with formatting phone first and then write imei.
If any problem post log so that we can see what error is there!
Wr.
Old 02-22-2011, 21:35   #3 (permalink)
Member: 148515
Thanks Meter: 13,862
hello!
please show logs of mode-1 and mode-2
we will help you
Old 02-23-2011, 12:01   #4 (permalink)
Member: 336192
Thanks Meter: 51
COM5 [VCP2] selected
module v3.25
Device: Autodetect 6253 NOR
Checking data, wait...
advanced flash detection disabled
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 910569401002426
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
boot packet size: 0400
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 20 sec
Remove/Install battery now !
mode 3
Old 02-23-2011, 12:34   #5 (permalink)
Member: 336192
Thanks Meter: 51
module v3.25
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: -------
Model: Autodetect 6253 NOR
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Connecting at 19200, wait...
mode2
Old 02-23-2011, 21:16   #6 (permalink)
Member: 148515
hello!
those was mode-2, mode-3
what about mode-1?
Old 02-24-2011, 06:01   #7 (permalink)
Member: 336192
Thanks Meter: 51
cant connect on that mode
Old 02-24-2011, 09:34   #8 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,856
Try with this imei writer and post result. Iam not sure will work for 6253 but you can try out.
Link- Dual_IMEI_Writer.zip - 4shared.com - online file sharing and storage - download
Wr.
Old 02-24-2011, 11:57   #9 (permalink)
Member: 1493233
Thanks Meter: 14
Wr.
not working sir
please help..........................
Old 02-24-2011, 12:27   #10 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,856
Originally Posted by 2stone.sunny View Post
not working sir
On which set have you tried and which cpu is inside the phone? I have tested this software, just to select right com port in setting and baud rate 115200.
BTW it's better to use Infinity Box for imei repair, only for 6253 there is problem.
Wr.
Old 02-24-2011, 21:19   #11 (permalink)
Member: 148515
hello!
it does not connect becuase in Engeneering menu is set wrong port.
now you have two options:
1. change IMEI via Bluetooth:
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
or
2. you must access engeneering menu and turn On com port
Set Engineer Mode *#3646633#
go to "Device", next "Set UART"
pick "PS config" and make it "UART 1"
save and exit.
try to change IMEI with mode-1 again
Old 02-27-2011, 05:06   #12 (permalink)
Member: 1043909
Thanks Meter: 49,400
Hello,
Please, try to use this new software:
http://www.infinity-box.com/download...dule_v3.77.rar
1. select model Huawei-G6620
2. make full flash backup for emergency case !
3. try to repair imei (DO NOT try to make other operations, this software for imei only)
Please, post here operation log.
Waiting for your results.
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 10:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 00:44
Page generated in 0.37824 seconds with 8 queries
