10-13-2015, 15:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | is micromaxx a310 supported Code: Operation : Read Flash [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND : Error : DA init Failed! Error code : 0x4 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! http://forum.gsmhosting.com/vbb/10894202-post709.html or i am missing something |
10-18-2015, 05:46 | #5 (permalink) | |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
Operation : Read Flash [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND : Error : DA init Failed! Error code : 0x4 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! | |
10-18-2015, 07:53 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Then I have no idea, because it work with my 6592 samples and other users samples well. a310 is not selling in my region. Have only a290 , which work perfect in all cases, because test on it. Have here accessonly to E313 with 6592 CPU. Would be great to check it, if something wrong - then can buy it. Without sample it take some time, when someone from tester catch it. Last edited by JayDi; 10-18-2015 at 08:02. |
10-18-2015, 13:20 | #7 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | only it can flash with YGDP tool if i can try with sptool it also hang untill i remove cable |
