11-30-2006, 18:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | please, see info: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
11-30-2006, 20:44 | #4 (permalink) | |
Did you tried to see my link ? What cable to use ? Where to find pinouts ? How to build cable ? www.infinity-box.com -> "support" -> "cables/pinouts" Infinity-Box cable compatibility: http://forum.gsmhosting.com/vbb/showthread.php?t=222631 | |
11-30-2006, 20:52 | #5 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Downoad Infinity-Box_cables_pinouts.rar and look at the 'Nec-N343i_Nec-E121.txt'. There are two testpoint pictures too. btw, you can find there all pinouts , and the arhive is reguary updated ith new supported models. belive me, If you searsh just a littlebit, Infinity_support and the stickkies can gave ALL the informations you need to operate it easily. If some unknown error occures ( search first !!!), post it here, you will have help |
11-30-2006, 21:18 | #6 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30807 Status: Offline Thanks Meter: 9 | Belive i search first and have this pictures in my computer but is not spicific and i have some dificult to made a cable! I try cut two cables and made one for this nec E121. My doubt now is what color goes at the the pinout of nec E121 because i don't have acess and i use a motorola cable! Thanks for your help |
11-30-2006, 21:21 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is a difference in "i don't see nothing about Nec E121 pinouts" and "some dificult to made a cable". You need to find Ground pin in cable and connect to phone Gnd. the try to apply Rx and Tx. If no connection: change Rx <-> Tx. |
12-01-2006, 01:20 | #9 (permalink) |
Member: 30807 Status: Offline Thanks Meter: 9 | The problem is to make a conection with Nec E121 because uses a special mini usb and i can find a cable in the market ( my box don't have is the firsts ones ) . to made one i need a special usb conector and i don't now here i can bye. i apreciate any sugestions. Thanks in advance |
12-01-2006, 13:54 | #12 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | You are wellocome. In addition: Those phones can be unlocked by two connecting methode: With wires directly to pcb, as you have done it, if you don't have coonector, or more easily with conector. Some samsung Hands-free models uses this type of connectors, I think, so in the future you can make one if more Necs will be brought to you to operate them. Good luck |
codes Siemens Cl75, Nec 343i, Toshiba TS10, NEC e121, Panasonic SC3 | hottt388 | NEC | 1 | 01-20-2008 18:12 |
FREE update for unlock by IMEI for ALL: NEC 343i, NEC E121 and Siemens CL75 | Multi-COM | GSM Mobile Links | 3 | 06-02-2006 08:08 |
Toshiba TS-10, Nec E121 | InfinitySupport | Infinity-Box | 29 | 03-02-2006 11:03 |
Do you need Nec E121 support ? | InfinitySupport | Infinity-Box | 21 | 02-11-2006 14:32 |
