09-17-2010, 11:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | mini china iphone need flashfile heres the log : COM2 [VCP0] selected module v3.22 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 355736010034239 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: APOLLO282SM_V1.1.0 Version: IPHONE_HW_V1.0 detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35573601003423 Finished, time used: 17 sec Remove/Install battery now ! |
09-17-2010, 13:08 | #2 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | COM2 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0__firmware_part_1_of_1_20100917-171057.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 00001D4F rom info ver: 05 sw version: APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61.BIN project-id: MOAIKE_6.61, 4BF5EAA8 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00001D4F.[APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN_E70209A7].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00001D4F._APOL LO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1_0.B IN_E70209A7_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 20 min 45 sec Remove/Install battery now ! |
09-19-2010, 02:56 | #4 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | i already rebuild imei but same problem ...the unit can recieve incoming calls and message but no outgoing calls can you provide me the same firmware like above post..thanks.. |
09-19-2010, 12:11 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashfiles/ChineseMiracle/_MT6225/32m/APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61__iPh one_SGH-W639_32m_En_Cn_Cn.B0M.bin flashfiles/ChineseMiracle/_MT6225/32m/APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61__T53 0_32m_En_Cn_Cn.B0M.bin |
09-19-2010, 13:12 | #7 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | COM2 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61__iPh one_SGH-W639_32m_En_Cn_Cn.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00001D4F.[APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN_E70209A7].rpl rom info detection finished device-id: 00001D4F rom info ver: 05 sw version: APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN project-id: APOLLO282SM_V1.1.0, A70902E7 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A POLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1_ 0__system_log_00001D4F_E70209A7_20100919-194737.B0X.bin Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A POLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1_ 0__system_log_00001D4F_E70209A7_20100919-200947.B0X.bin Finished, time used: 22 min 48 sec Remove/Install battery now ! Success Flashing but the display is inverted and hung only with logo.... i will the other one... |
09-19-2010, 13:25 | #8 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | COM2 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00001D4F.[APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61.BIN_ 6FDFB0E8].rpl rom info detection finished device-id: 00001D4F rom info ver: 05 sw version: APOLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61.BIN project-id: MOAIKE_6.61, E8B0DF6F code offset: 00000000 ffs offset/size [01]: 01E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01E00000 flash: EC227E22632260:18E59F00000000 checking area [00000000]: 00080000-01FFFFFF... ffs/eeprom found near: 008C0000 Detected ffs/eeprom address is non-standard: 008C0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 008C0000 detecting ffs/eeprom size... ffs/eeprom size: 01740000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:008C0000-01FFFFFF firmware area: 00000000-008BFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A POLLO282SM_PCB01_GPRS_MT6225_S00.MOAIKE_6_61__syst em_log_00001D4F_6FDFB0E8_20100919-202230.B0X.bin Finished, time used: 2 min 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! i do complete format the phone is dead i will try again the other flashfile ......... |
09-20-2010, 06:13 | #9 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | COM2 [VCP0] selected module v3.22 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MOAIKE_6.61 Version: IPHONE_X_3.31 detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 352 warning: wrong packet cs warning: wrong packet cs items cleared: 352 of 352 building list... done items remains: 0 Finished, time used: 40 sec Remove/Install battery now ! hi infinity team the flashfile is not correct that firmware is for iphone 2 sim my iphone mini is one sim only need other compatible flashfile thanks... |
09-20-2010, 09:59 | #10 (permalink) |
Member: 757159 Status: Offline Thanks Meter: 467 | Heres the detailed orig firmware : anybody have good back up like this....... COM2 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9103:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00001D4F.[APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN_E70209A7].rpl rom info detection finished device-id: 00001D4F rom info ver: 05 sw version: APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN project-id: APOLLO282SM_V1.1.0, A70902E7 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detecting ffs/eeprom structure pass 1... ................................... ffs/eeprom: detect std location pass #1... .................................................. ................................................. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: APOLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1 _0.BIN detecting firmware build... .................................................. ................................................. firmware date/time: 2009-08-14 18-05 hw1: IPHONE_HW_V1.0 hw2: APOLLO282SM_V1.1.0 done detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. ................................. language parameters detected detected languages: En Es Th Vn Cn Tr Cn Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A POLLO282SM_PCB01_GPRS_MT6225_S00.APOLLO282SM_V1_1_ 0__system_log_00001D4F_E70209A7_20100920-165734.B0X.bin Finished, time used: 2 min 31 sec Remove/Install battery now ! |
09-24-2010, 21:11 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i guess best way to repair this phone is to find same working phone and read out full backup |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
