09-10-2008, 11:04 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | MM95_N95 Mini.. Pinout and Flash Backup.. mm95 leady pinout and flash backup.. Eeprom and flsh file.. eeprom[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN]_20080910-122616.B0E flash[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN]_20080910-123823.B0M http://rapidshare.com/files/14407917..._Mini.rar.html Pinout... software version: 1.06 cable type: 1x12 (L12C) platform: MT6205, MT6217-MT6228 searching adapter at COM4... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 CPU: MT6225 result: Rx:5 Tx:6 time required: 28 sec Power On ! and log... Code: COM18 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:9203:0007 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.03271A01.[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN_FBBA1112].rpl ==================== New firmware detected: C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 03271A01 identification#1 protocol ver: 04 ver. sw1: C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN ver. sw2: C95_3.00.1, EDEE4504 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN]... file saved: C:\Documents and Settings\Full_Tell_2\Desktop\MM95_N95_Mini\flash[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN]_20080910-123823.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_03271A01_C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN_FBBA1112_20080910-123956.B0X.bin Finished, time used: 785 sec Remove/Install battery now ! smart-card disconnected b.r.. |
The Following User Says Thank You to LoveLess For This Useful Post: |
09-10-2008, 23:42 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @LoveLess Thank you. Please, in future send files (or links) to [email protected] to avoid lost files. |
10-23-2008, 19:40 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | thanks loveless good work my pinfinder search not found pin mm95 ??? infinty pinfinder cable L12C and manuel pin rx:5 tx: 6 not connect ??? veking cable add infinty pinfinder search pin found rx:8 tx: 7 ??? |
nokia n96 pinout and flash backup | delchoni | Infinity-Box | 10 | 02-08-2011 18:05 |
R290 Pinouts and Flashes ? | jan | Cruiser Suite | 6 | 01-25-2011 10:10 |
New N6120o pinout and good backup download here | alexander.tech | Infinity-Box | 0 | 01-02-2010 05:28 |
Chinese CECT 8380 pinout and Flashes ? | Bay | Infinity-Box | 1 | 05-22-2007 10:11 |
i have a doubt whit Rsd and Flash Backup | Amartt | Motorola Hardware Repair | 1 | 11-21-2006 01:36 |
