11-09-2012, 13:22 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: gsmservice city
Member: 567810 Status: Offline Sonork: Xiaomi direct Thanks Meter: 30 | Mmodule 4.40 error: can not write flash (0): Philips X 513 dead after upgrade. I choose Autodetect MT6250-6253 etc. Philips X 513 is not in list Code: COM19 [ProlificSerial0] selected module v4.40 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: write flash write: Firmware NOLLEC53_09B_PMWY_PCB01_GPRS_MT6253_S00.X513_M6253_1048_01_V09A_RU.BIN_FLNPF38F4050M0Y3DE__fullflash_20121107-161531.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00AD]: 0098:005F00000000 [TOSHIBA] TC58FYM8T8D chip size: 32Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: X513_M6253_1110_01_V13A_RU detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NOLLEC53_09B_PMWY_PCB01_GPRS_MT6253_S00.X513_M6253_1110_01_V13A_RU.BIN_FLNPF38F4050M0Y3DE project-id: X513_M6253_1110_01_V13A_RU, 00000000 code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.40, database date: 18.09.2012): NOLLEC53_09B_PMWY_PCB01_GPRS_MT6253_S00.X513_M6253_1110_01_V13A_RU.BIN_FLNPF38F4050M0Y3DE This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0BD8:S_DA_NOR_BLOCK_DATA_UNSTABLE error: last error: 0BD8:S_DA_NOR_BLOCK_DATA_UNSTABLE Disconnect... done Finished, time used: 57 sec Remove/Install battery now ! |
