02-03-2010, 21:04 | #1 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 679853 Status: Offline Thanks Meter: 5 | MModule" v3.09 "MModule" v3.09 released: .Konka-K120 model supported .Konka-EC006 model supported .Konka-D280 model supported .Konka-C220 model supported .Konka-C623FM model supported .Konka-D316 model supported .Alcatel operations improved (new firmware types supported) .firmware database updated .new flash files uploaded in support area |
02-04-2010, 09:27 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,692 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=918175 | |
02-04-2010, 10:40 | #3 (permalink) |
Freak Poster Join Date: May 2003 Location: Ivory coast Age: 47
Member: 28749 Status: Offline Thanks Meter: 48 | 203x alcatel 203x-2BRGTE5 (orange ivory coast) always locked!!! COM7 [VCP0] selected module v3.09 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C79:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 377 provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CC30 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124->0827CDA8 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247403042405 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100204-093450.B0X.bin Finished, time used: 1 min 48 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-06-2010, 19:43 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | OT203x-2BRGTES, cant unlock COM6 selected module v3.09 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7F52:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN project-id: MAUI.08A.W08.36.SP1.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 365 provider: 203X-2BRGTE5 customization: CM36CC20 customization: XM36CC20 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM36CC20 error: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247403027244 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files (x86)\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28__system_log__00000000_2010 0206-184028.B0X.bin Finished, time used: 1 min 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-10-2010, 15:45 | #8 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | yes i try with another simcards, without sim i can enter in phone menu but with simcard same thing.............. read my log its showing me this error message..... error: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support |
02-17-2010, 19:17 | #11 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | @yellowboss bro i try today again with 3.14 and 3.16 both version get problem after sp unlock on phone screen it just appearing alcatel welcome logo and go off its just doing like this now.........after i select repair tab and press repair security area, after successfully repair security area phone came back on same pusition ...... |
02-17-2010, 20:39 | #12 (permalink) | |
We are working now to find solution for this problem. | |
02-18-2010, 08:21 | #13 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | reply yes man you are right at this time many operateur use this lock but we know you are working on this problem and we are sure you will the first o find solution |
MModule" v3.28 released | malektalha | Infinity-Box | 2 | 03-23-2010 09:53 |
Smart-Clip v3.09 and S-Card v1.09. | GSM_Support | Smart-Clip | 17 | 09-02-2007 07:31 |
6610 v3.09 cheap flasher problem | king_loyd | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-17-2004 11:57 |
Nokia 6610 V3.09 Ppm B? | crossings | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-03-2003 02:06 |
Nokia 7650 4.xx Flash N 7210 V3.09 Flash | benny78 | WD2 & APE (Symbian Phones) | 1 | 10-27-2002 03:26 |
