Old 07-29-2009, 10:49   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
MModule_v2[1].82 check bugs
i have problem with 2 phones, S319x and tokyo when i try to unlock.
COM6 [VCP0] selected
module v2.82
Device: Alcatel-S319X, S319A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
S319X-2BVGGB1_XH16VU10_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-06-20_En_De_Ru_Bg_Ua_simfree.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:0172:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
ffs address assigned: 00C00000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) check...
security area (code #1) fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090729-101438.B0X.bin
Area: Firmware
Write: Firmware
error: wrong answer: A1
error: flash write error: 00032000:00002000
error: flash write error: 0007C000:00002000
error: flash write error: 0015C000:00002000
error: flash write error: 003DA000:00002000
error: flash write error: 00738000:00002000
error: flash write error: 0073C000:00002000
error: flash write error: 007BE000:00002000
error: flash write error: 007F6000:00002000
error: flash write error: 0080A000:00002000
error: flash write error: 00822000:00002000
error: flash write error: 0089C000:00002000
error: flash write error: 008C2000:00002000
error: flash write error: 0090E000:00002000
error: flash write error: 0094C000:00002000
error: flash write error: 00A4A000:00002000
warning: wrong cs at 0x00001000, retry...
read error recovered
warning: wrong cs at 0x0063C84C, retry...
security area (code #3, part #2) calculation...
customization: CH16VU10
done
warning: wrong cs at 0x00BFA400, retry...
warning: wrong cs at 0x00BFE400, retry...
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
error: flash erase error: 00D10000
error: flash erase error: 00E00000
error: flash erase error: 00E50000
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090729-103126.B0X.bin
Finished, time used: 1032 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 07-29-2009, 11:29   #2 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
module v2.81 is ok.
module  v2.81
"format ffs" active
write: Firmware
S319X-2BVGGB1_XH16VU10_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20_2008-10-29_En_De_Ru_Bg_Ua_simfree.B0M.bin
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN
sim-lock status: disabled
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090729-105052.B0X.bin
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090729-105828.B0X.bin
Finished, time used: 481 sec
Old 07-29-2009, 18:00   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
good information plz remove this bug infinity
Old 07-29-2009, 18:11   #4 (permalink)
Member: 1058944
Sonork: 100.1582347
I have post before also but no reply and no action.
Due to this bugg exe my sx200 FLY is dead and i have paid customer.
ALthought infinity is best. thanks
Old 07-29-2009, 18:14   #5 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thankx for F@RUKS your information ....... and Infinity team do this corect..........
Br.
amar181
Old 07-29-2009, 18:32   #6 (permalink)
turca's Avatar
Member: 211017
Same problem in chinesse miracle 2.86
Br.
amar181[/QUOTE]
Old 07-29-2009, 18:51   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks to all good friends !
We are working non-stop to fix all possible bugs.
Please, if you really want to help, never post messages like "same problum" due to this kind of message is nothing and we will close all threads with posts like "same problem".
Thank you for your kind understanding and help !
@GSM-STUDENT
please be honest, do not write here strange words.
if you see that this problem with latest version you are able to download previous version and flash phone with older version.
no need to pay to anybody, just download latest stable release and make job.
Old 07-29-2009, 21:06   #8 (permalink)
GSMsurgeon's Avatar
Member: 6524
Today kiled 1 fly sl399e by unlock new mmodule
I have back up eprom but cant write back.also cant flash firmware too error in 98%..please post 2.81 exe please...
Thanks
George
Old 07-29-2009, 22:07   #9 (permalink)
Member: 130995
Thanks
George
what is the error exactly ?
you can download previous software versions from support area from "archive" folder.
Now it's final warning !
One more message without problem description and threads with explanations like "oh... problem..." will be closed.
Old 07-29-2009, 22:12   #10 (permalink)
GSMsurgeon's Avatar
Member: 6524
sorry !!! will post tomorow
I will post log tommorow...sorry for the inconvience.....
Old 07-30-2009, 08:13   #11 (permalink)
Member: 1058944
Sonork: 100.1582347
Arrow Sorry for Truth.
@GSM-STUDENT
Sir what i have write its true. You can see my thread all is there. Now phone is with white screen and ok only no lcd. Even with old version of mmodule can only flash it but no lcd comes. Its true sir great bug in new exe must be removed as soon as possible. I have send backup also but still no responce. thanks
Fly sx-200 Dead by infinity.
thanks
Old 07-31-2009, 10:18   #12 (permalink)
Member: 130995
@GSM-STUDENT
You have a solution now: use previous MModule version and flash phone.
Please, let me know what kind of response you are waiting for.
Old 07-31-2009, 10:35   #13 (permalink)
Member: 1058944
Sonork: 100.1582347
Sorry sir,
I was not this mean. I dont want to disheart or disoppoint you. Once again sorry. Wish you all the best and live long with infinity. thanks
raja16sep
Old 07-31-2009, 10:52   #14 (permalink)
Member: 130995
Hello,
Thank you !
If you will have any problems you are always welcome to contact us in forum or via e-mail.
Old 07-31-2009, 13:18   #15 (permalink)
GSMsurgeon's Avatar
Member: 6524
I have done my fly SL399E by old module 2.79
Shoud be bugs in latest mmodule... thanks to F@RUKS ,for bugs information in new module.. sorry InfinitySupport.. please fix it..
Thanks
George
check bug in server tahir kazmi PolarBox 2 3 10-19-2008 13:59
ub team .. plz check bug flashing bb5 failed amei8141 Universalbox 3 07-17-2007 05:37
@ Zulea: Please check bug in v8.7 yeldar SonyEricsson (USB-Smart) 31 07-30-2006 16:23
New version of BF3/4 Tool 1.82 for sale Henrich SGU Main Sales Section 0 10-17-2002 08:11
t191 ver 1.82 unlock? gsmsalers ODM (Original Design Manufacturing) 13 10-12-2002 12:39
Page generated in 0.56640 seconds with 11 queries
