mmx aq4501 hang in logo-flashing error as PROTECT 1 -write error-now dead-help me error as below http://i66.tinypic.com/35at451.jpg set came with hang in logo problem-now dead help me |
please chek emmc w/r .if it is write protected you need emmc box to remove write protection. |
post full log read info & try with og tool |
Chinese Miracle II [MTK module] v 1.44 Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 109 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040507A1D6BC812F Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040507A1D6BC812F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 388E8254F6309C8167CE9AB15A00BFBC INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! is it emmc write protected? |
Use SPFT To Flash this done bcz it's android one set & so far I know cm2 not support it |
try with same ver flash file write infinity mtk 1.50 http://forum.gsmhosting.com/vbb/f296...tures-2103391/ |
Fastboot devices fastboot oem unlock then download the flash file from here https://drive.google.com/uc?id=0B6u4...WZNb2l4dkxDNzg then flash with sp tool version SP_Flash_Tool_v5.1524.00.000 https://androidmtk.com/smart-phone-flash-tool 100% tested salution if face any problem then connect me with snoork |
Hello, Why are you using so old version? And team is trying to add Android One series phones, it's not supported yet fully. Br. Infinity Box Support Team. |
by command fastboot oem unlock |
1st u can try read dump ( Not factory fw ) from working phone via Infinity CM2 then write to faulty phone Via Infinity CM2 after phone goes to alive if still show logo only just flash this rom Micromax_AQ4501_V3_23.03.15 (lollipop Version)_(by_xdafirmware.com) SP_Flash_Tool_Windows_v5.1516.00 Donload only ( mode ) ( Bw : Don't use other option at SPFT ) Tested 100% :) |
