Old 06-21-2016, 04:54   #1 (permalink)
Member: 946381
Thanks Meter: 136
mmx aq4501 hang in logo-flashing error as PROTECT 1 -write error-now dead-help me
error as below
set came with hang in logo problem-now dead
help me
Old 06-21-2016, 05:12   #2 (permalink)
Member: 278546
Thanks Meter: 139
please chek emmc w/r .if it is write protected you need emmc box to remove write protection.
Old 06-21-2016, 05:27   #3 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 410
post full log read info & try with og tool
Old 06-21-2016, 05:34   #4 (permalink)
Member: 946381
Thanks Meter: 136
i dont know to check emmc write protected or not-so i post info
Chinese Miracle II [MTK module] v 1.44
Operation : Check / Read Info [ v1.44 ]
Wait for phone...
Phone found! [ 109 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040507A1D6BC812F
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040507A1D6BC812F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 388E8254F6309C8167CE9AB15A00BFBC
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
is it emmc write protected?
Old 06-21-2016, 06:50   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 1,840
Use SPFT To Flash this done bcz it's android one set & so far I know cm2 not support it
Old 06-21-2016, 07:19   #6 (permalink)
Abul Basher's Avatar
Member: 1675107
Sonork: n/a
Thanks Meter: 116
try with same ver flash file write infinity mtk 1.50 Infinity Chinese Miracle-2 MTK/Mediatek v1.50 - MTK FP extra features
Old 06-21-2016, 08:10   #7 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 690
Originally Posted by zone3 View Post
error as below
help me
this phone is with lock bootloader first unlock the bootloader
Fastboot devices
fastboot oem unlock
then download the flash file from here
https://drive.google.com/uc?id=0B6u4...WZNb2l4dkxDNzg
then flash with sp tool version SP_Flash_Tool_v5.1524.00.000
https://androidmtk.com/smart-phone-flash-tool
100% tested salution
if face any problem then connect me with snoork
Old 06-21-2016, 09:39   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Hello,
Why are you using so old version?
And team is trying to add Android One series phones, it's not supported yet fully.
Br.
Infinity Box Support Team.
Old 06-21-2016, 16:24   #9 (permalink)
Member: 946381
Thanks Meter: 136
Fastboot devices
fastboot oem unlock
NOW PHONE dead-any way to bootloader unlock ?
by command fastboot oem unlock
Old 06-22-2016, 12:05   #10 (permalink)
Member: 770503
Thanks Meter: 986
Now if your phone connected to infinity cm2 then no need to unlock bootloader.
1st u can try read dump ( Not factory fw ) from working phone via Infinity CM2 then write to faulty phone Via Infinity CM2 after phone goes to alive if still show logo only just flash this rom
Micromax_AQ4501_V3_23.03.15 (lollipop Version)_(by_xdafirmware.com)
SP_Flash_Tool_Windows_v5.1516.00
Donload only ( mode ) ( Bw : Don't use other option at SPFT )
Tested 100%
Old 02-12-2018, 07:18   #11 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 624
Fastboot devices
fastboot oem unlock
thanks broo its working solution
Page generated in 0.36121 seconds with 7 queries
