12-07-2017, 18:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Mobicel Vivo Help Code: [SCATCHECK] : Missing File : C:\Users\Yw'S\Desktop\Mobicel_Vivo_Single_SIM_MT6580_5.1\Mobicel_Vivo_Single_SIM_MT6580\Firmware\cache.img [SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter! Start at : [07-12-2017 / 18:56:14] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D42025EE6542AC2CF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! Finish at : [07-12-2017 / 18:56:33] Start at : [07-12-2017 / 18:57:04] Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D42025EE6542AC2CF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [07-12-2017 / 18:57:15] |
12-07-2017, 20:54 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Mostly this error belongs wit Hardware faults,like Emmc damaged,or flashed wit wrong preloader. Check Google about Enable Dram fail 4032 error. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
12-08-2017, 10:15 | #4 (permalink) | |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | It's wrong preloader fault Quote:
Code: Selected 0-By CPU: MT6580 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM5) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) SAMSUNG 0x464a32374d42 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 150100464A3237 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM21) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Starting flash. Download firmware to flash now... Wait untill phone will start charging. | |
