Old 02-07-2011, 09:59   #1 (permalink)
Member: 430612
Thanks Meter: 301
mobitel E71s FORMATTING OK BUT STILL DEAD
COM9 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9203:0004
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:2AEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.26, database date: 13.01.2011):
CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102.BIN
project-id: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102__ffs...
file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CK.MOBITELE71S.E1 7.F1.TVF.1.0.T01D091102__ffs_20110207-085227.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 7 min 53 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 02-07-2011, 13:17   #2 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Bro check it for hardware.
Old 02-07-2011, 15:57   #3 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
Full flash your phone
Old 02-07-2011, 21:39   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
make backup and flash it with some similar flash file starting with "CK."
Old 02-08-2011, 05:46   #5 (permalink)
Member: 430612
Thanks Meter: 301
which file must i use?,,,,,,,,,,,,,,,,,,,,,
Old 02-08-2011, 21:28   #6 (permalink)
Member: 148515
hello!
as i told already: any file from support which is starting with "CK."
Old 02-09-2011, 10:59   #7 (permalink)
Member: 430612
Thanks Meter: 301
reading: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_HL_L7SM _230_071101_LD0_0V0_SA75_CTF_BT__ffs...
file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CKT26_06B_PCB01_G PRS_MT6226_S01.SWAN+_6226_HL_L7SM_230_071101_LD0_0 V0_SA75_CTF_BT__ffs_20110209-112727.B0E.bin
flash: EC240200000000:2CEA0000000000
Code CRC check error fix...
firmware do not have "Code CRC check error" area
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 28 min 40 sec
i flash it but same problem
Old 02-09-2011, 20:45   #8 (permalink)
Member: 148515
hello!
ok, here it is:
flashfiles/ChineseMiracle/_MT6205-MT6227/CK.E71S.E17.F1.TVF.1.0.T03D090929_16m_En_Fr_Es_Id_ Tr_Farsi_Pt_Ar.B0M.bin
Old 02-10-2011, 06:00   #9 (permalink)
Member: 430612
Thanks Meter: 301
ok i will post result......
Old 02-10-2011, 07:39   #10 (permalink)
Member: 430612
Thanks Meter: 301
module v3.26
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
flash: EC240200000000:18E59F00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
rom info structure: [standard] type (04)
TCL-ID is absent
rom info ver: 04
sw version: CKT25_GEMINI_PCB01_GPRS_MT6225_S00.A522-5320_8G-2_109_080728.BIN
project-id: A522-5320_8G-2_109_080728, 00000000
TCL-ID is absent
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
ffs/eeprom chip: 00
reading: CKT25_GEMINI_PCB01_GPRS_MT6225_S00.A522-5320_8G-2_109_080728__ffs...
file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CKT25_GEMINI_PCB0 1_GPRS_MT6225_S00.A522-5320_8G-2_109_080728__ffs_20110210-083501.B0E.bin
====> Write ...
done
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 00000000:00002000
error: write operation failed
Write Fail
Finished, time used: 5 min 31 sec
same problem phone still dead
Old 02-10-2011, 20:51   #11 (permalink)
Member: 148515
hello!
this time writing failed:
Write: Firmware
Write Fail
you must search for reason
FBUS works but MBUS not! PLS Help! Upo Nokia Hardware & Hardware Repair 5 09-12-2000 14:54
6110 unlocked but wont give reception KingOfKingston Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 04-10-2000 22:15
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Still with nokia 5110 ver 5.24 VirtualM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-11-1999 18:57
DOES THE CELLNET DIGA HACK STILL WORK??? SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-04-1999 13:55
Page generated in 0.21459 seconds with 10 queries
