11-16-2016, 10:28 | #1 (permalink) | ||
Insane Poster Join Date: Nov 2009
Member: 1160161 Status: Offline Thanks Meter: 13 | MobiWire Atohi MT6276 need network unlock here is info: Quote:
Code: Operation : Read Flash [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : FF Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x80 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0056 , [TOSHIBA] TC58NYG0S8C FLASH_DIE0 : 0098 00B1 0080 0055 FLASH_DIE1 : 0072 0016 0008 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00015000 EXT_RAM : 0x04000000 Reading Flash Content now ... Read Ok, 0x07F80000 bytes Saved to : C:\InfinityBox\CM2MTK\Read_out\MT6276_025F25752321_Infinity.bin Done! Elapsed: 00:01:43 Reconnect Power/Cable! Quote:
MianLinks | ||
10-11-2017, 10:46 | #6 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hey.. i have the same device and it is not booting.. it is working there is no pb.. Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 46 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
