07-01-2017, 07:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: PILIPINAS
Member: 1604158 Status: Offline Sonork: 100.1614304 Thanks Meter: 122 | Mobiwire Pictor unlock support Code: Start at : [7/1/2017 / 1:56:39 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7E3FD03DFFF30E4AE4AD34FB4DE37EC9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Code: Card found : S/N : 779D0B12 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7E3FD03DFFF30E4AE4AD34FB4DE37EC9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : UL18D_XB39E_EE_PCB01_gprs_MT6260_S00.V04_M160330_UL18D_XB39E_EE_MP.bin FileVersion : V04_M160330_UL18D_XB39E_EE_MP Saved to : C:\InfinityBox\CM2MTK\Read_out\UL18D_XB39E_EE_PCB01_gprs_MT6260_S00.V04_M160330_UL18D_XB39E_EE_MP.bin Done! Elapsed: 00:00:57 Reconnect Power/Cable! tnx back up firmware to follow Last edited by -=jeovel=-; 07-01-2017 at 07:13. |
07-01-2017, 07:21 | #2 (permalink) |
Member: 1604158 Status: Offline Sonork: 100.1614304 Thanks Meter: 122 | back up firmware here https://www.4shared.com/file/bFlX6h3...gprs_MT62.html |
12-26-2018, 10:27 | #5 (permalink) | |
Insane Poster Join Date: Sep 2017 Location: Jhelum
Member: 2762776 Status: Offline Thanks Meter: 22 | Phone dead after writing this firmware Quote:
Kindly upload another flash file because I forgot to backup my phone and now after writing this flash file the phone is dead. | |
03-07-2019, 08:20 | #6 (permalink) | ||
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
I make backup of this device before install dump firmware but now InfinityBox CM2MTK application ask me that this is bad file detected. Do you have a valid firmware ? | ||
